RaspberryPi Image and No Audio
swnoska
Postby swnoska » Sat Dec 08, 2018 12:16 am
Anyone else having audio issues with the RaspberryPi? I did not see any threads on this subject, but I could have missed it.
No audio using CubicSDR on the image. I also did not get any audio by going to youtube and playing a video. No audio from anything. When I select the output choice, the volume drops all the way down. When I increase the volume I still cannot hear anything. Went to the raspi-confi area and also selected 3.5 jack. No change.
My setup...
RPi 3 Image – V0.4 (19th Nov 2018)
RaspberryPI 3 B+
Monitor: VGA monitor. Using HDMI to VGA converter. (I also tested this pi with a HDMI equipped monitor with speakers. No sound thru HDMI either.)
Using audio jack to amplified speakers.
RSP1
I confirmed my hardware is good by running the RaspberryPI with the Raspbian image and I experience no audio issues. On either the VGA (w/speakers) or HDMI monitor.
I have reimaged my Samsung 32gb SD card several times and still experiencing the same no audio issue.
Any ideas what may be wrong?
thanks
SWN
Mikesimpson
Re: RaspberryPi Image and No Audio
Postby Mikesimpson » Sat Dec 08, 2018 10:35 pm
I get exactly the same here, no audio after connecting to a HTMI monitor. I did a Google search for this and there are dozens of others with the same problems, along with some suggestions for a fix but I have not got it working yet.
Mike
mikexeno
Postby mikexeno » Sun Dec 09, 2018 5:25 pm
You can try dropping to Terminal and selecting the correct output vs having it on AUTO
sudo raspi-config
Not sure how current the below images are.
Mikesimpson
Postby Mikesimpson » Sun Dec 09, 2018 8:45 pm
Thanks very much Mikexeno, I will try that later today.
Mike
swnoska
Postby swnoska » Sun Dec 09, 2018 9:49 pm
I went to the terminal and did the switch from Auto to 3.5 jack.
However, this had no effect for me on getting the sound issue corrected.
SWN
mikexeno
Postby mikexeno » Mon Dec 10, 2018 5:38 pm
That's strange. Let me see if anything is posted online with a possible fix.
chrisneal
Postby chrisneal » Wed Dec 12, 2018 5:41 pm
I have same issue with no sound on the new image v0.4.
I have tried switching the audio over and auto selecting. nothing worked.
checked ver 3 and that's fine so my hardware is working.
Can any one give a fix, or will we have to wait for a fix on the image?
is there an idiots guide to installing new drivers for the sound card?
algy
Postby algy » Sat Feb 23, 2019 6:11 pm
Hi
I am having exactly the same symptoms as described, below.
Did anyone find a 'fix' for this?
Thanks.
Al
gw3ltx
Postby gw3ltx » Tue Mar 05, 2019 11:27 am
Has anyone solved this issue?
I have just set up a Pi 3B with the downloaded image V0.5 and have no sound
even when trying various sources.
Sound works using the original Raspberry Pi image.
Very disappointing as this is the first time I have managed to get my RSP1 to be
recognised in a Linux based operating system.
Bob
itstechpro
Postby itstechpro » Wed Mar 06, 2019 5:27 pm
Hi all...
Same problem here. Loaded 0.4 on my Pi 3B+ ... Cubic comes up nicely but no audio on the on board jack. Changed the settings in config to always come up on the jack .... no audio. Tried a sound card; card recognized the only option I get on Cubic is Pulse Audio .... no other modem options come up. Is there a new release to take care of this problem.
JM
Users browsing this forum: Baidu [Spider] and 9 guests
