Yaesu FT2000 synchronize with SDRUno
An area to exchange hints and tips on various rig control software, also a place to ask the community questions if you are having problems.
Rafa3215
Post by Rafa3215 » Wed May 15, 2019 11:58 am
Hi friends
My name is Rafael S. Lopez and I am a Spanish radio ham with call sign EA5TV and I have been using Rsp 1A for a long time, which I am very satisfied with.
Previously I have been using the RSP1 A with a Yaesu FT1000MP transceiver and everything worked OK.
A few days ago I purchased a new transceiver, a Yaesu FT2000 and I proceeded to make the connections with the RSP1A and a problem has arisen. For synchronization of the transceiver with the SDRUno program, I installed the Omnirig and also used VSPE, in which I created a splitter to be able to use the same Com1 port for several programs. This same configuration worked OK with the FT1000MP, but now it turns out that when I activate RSync in the RX Control window, the transceiver automatically goes to transmission.
I have reviewed the configurations of the Com1 port, the Omnirig port and the VSPE port, I have varied the speed of the different ports, I have checked the configuration of the Yaesu CAT port, and I can not get Ok to work.
What can be the solution to my problem?
Best regards.
Rafael S. Lopez
EA5TV
PS.- Translated with Google Translator.
AK1MD
Re: Yaesu FT2000 synchronize with SDRUno
Post by AK1MD » Mon Jun 17, 2019 4:47 am
I tried to connect my FTDX 5000 today with RSP 2 and HRD and it did not work. Will need more help.
73, Alex
User avatar
mikeladd
Post by mikeladd » Sat Jul 06, 2019 2:08 am
Have you followed the setup video and PDF guide?
Video is here
https://www.youtube.com/watch?v=fIDoNpLQ3MA
Guide is here
https://www.sdrplay.com/docs/HRDandSDRuno.pdf
If your using apps that need the same com port, You will need VSPE and setup a "splitter" in VSPE.
