How to get the output from SDRConsole to AGWPE
1. I want to monitor APRS from satellites and on 144.390. I think it involves VAC, and I have that isntalled, but I don't see that option in SDRConsole to send the output to VAC.
2. When I turn on AGWPE, it puts a carrier right in the middle of the FM passband, just below the monitored freq. When I exit AGWPE, the carrier goes away.
3. I am still seeing a carrier right in the middle of the display, with HDSDR and SDRConsole. I do NOT see it when I run SDRSharp with my RTL 1090 USB stick.
Mark Lunday, WD4ELG
Mark Lunday, WD4ELG
Re: How to get the output from SDRConsole to AGWPE
Mark,
on the VFO window, click on audio/playback device and select your relevant VAC
and the center spike should disappear if you are on a frequency after about 30sec, but Simon is working on an update still for the new API, did you copy the new API into the sdr-console folder?
Paul - NN4F
Paul - NN4F
- vac.JPG (54.37 KiB) Viewed 12108 times
