Where is RDSW button?
tomas112
Post by tomas112 » Mon Aug 29, 2016 9:58 am
Hi all
I just bought a DISPlay (is still on the way). While I use my RTL2832 (through ExtIO_RTL2832.dll). BUT on RX panel doesn´t appear RDSW button!!!!. I have the newest versión of SDRuno: "Rel. 1.02. 23rd June, 2016, RSP edition". what happen?, I set something wrong?.
Best regards
Misterj
Re: Where is RDSW button?
Post by Misterj » Mon Aug 29, 2016 7:18 pm
tomas112, as long as my SDRPlay is plugged into the USB port BEFORE SDRuno is opened, the button is there. Please see page 14 here. SDRuno does not work properly when opened without the radio recognized by the computer. Please post any error message (screenshot) you are getting. Open an administrator command prompt, enter winver and post the results here.
Thanks and enjoy, John.
tomas112
Post by tomas112 » Tue Aug 30, 2016 11:22 am
Hi Misterj
Problem is that I have not a SDRPlay, I have a RTL2832U device....When I open SDRUno the program does not recognize it.
Always appears this:
Misterj
Post by Misterj » Tue Aug 30, 2016 5:26 pm
tomas112, please see this post. You need some additional SW. Hope this helps. Enjoy, John.
Rod2117
Post by Rod2117 » Tue Aug 30, 2016 7:20 pm
I have had the same error message. I managed to get rid of it by going into the settings on the RX screen of Sdruno. One of the tabs brings up receiver/transceiver. I unchecked the box at the bottom marked enable. Sdruno now works fine and I no longer get that error. I am using win 10 with the rsp.
Hope this helps
Rod2117
