SDRuno 1.03
SDRuno 1.03
Awesome!
Re: SDRuno 1.03
Is the 1.03 installer supposed to erase all my workspace/window settings? Because it did.
Re: SDRuno 1.03
Well Thanks for erasing every setting and everything I just configured over the last couple of days!
even my memory presets are gone!
GONE!
GONE!
God knows all, Menace knows more.
¯\_(ツ)_/¯
¯\_(ツ)_/¯
Re: SDRuno 1.03
If you look in the registry all the 1.02 settings are still there. If you are familiar with regedit you can possibly move them forward to 1.03 - there were too many changes that affected existing installs to maintain the same registry settings.
Re: SDRuno 1.03
i tried to export und import the reg settings, but it dit not work.any solution?
Re: SDRuno 1.03
the old settings are in the 1.01 folder, the new ones in 1.03 - some will be able to be copied across but the ones that clash with new settings won't.
If you are familiar with regedit you can export the 1.01 folder, modify the text file, change 1.01 to 1.03 BUT please be prepared for crash if there are clashes.
Only do this if you are a confident regedit user. Modifying the registry can cause system issues if you make a mistake.
