monitor SDRUno audio output into FLDIGI
km4udx
Post by km4udx » Thu Mar 08, 2018 10:04 pm
Hello! Newbe here. What is the secret to monitoring audio that I send to FLDIGI? I can get the audio to EITHER FLDIGI or speakers, and either works GREAT. But it is driving me crazy to have to change the selection, hit start/stop, listen, then do select VB and stop/start to get FLDIGI working. I've looked and looked in FLDIGI (even read the user guide!) and I don't see any way in the FLDIGI sound config to have the FLDIGI pass the audio through to the laptop speakers (which was my first approach). This is the classic "monitor" function. But no love with FLDIGI as I can't find a audio monitor function.. So back to SDRUNO (and I love my SDRPlay2 by the way -- what a GREAT receiver!!!).
SDRUno RX Settings -> WME Ouput Device has two options...
- CABLE Input (VB-Audio
- Speakers (High Def
and they both work fine! But I want to feed FLDIGI with SDRUNO and monitor the audio in my laptop speakers at the same time...oh wise ones...what is the secret???
km4udx
lenahh
Re: monitor SDRUno audio output into FLDIGI
Post by lenahh » Sat Mar 10, 2018 12:14 pm
Right click on your speaker icon, select "Recording Devices" - "CABLE Output" and then the "monitoring" tab.
Now you can enable monitoring the virtual cable and select the output device.
Works fine witch fldigi, HRD, WSJT-X and so on.
Only thing missing is a shortcut to switch monitoring on/off ;)
NoelC
Post by NoelC » Sun Mar 11, 2018 8:10 pm
Personally I bought a small audio cable (a few inches long, mini-plug to mini-plug) and wired my line out to my line in. Those connectors weren't in use for anything anyway, so...
-Noel
lenahh
Post by lenahh » Sun Mar 11, 2018 8:23 pm
But you will have the same problem witch a hardware cable - you need to monitor your line/mic-input to your internal speakers.
Post by Mike2459 » Tue Mar 13, 2018 1:17 am
In addition to what Lenah mentioned above you may also have to select your speakers (at Playback through this device:) if they are not the default output device - mine wasn't - SPDIF was the default, which I don't use.
Cable out.JPG (30.79 KiB) Viewed 24808 times
N1EYZ
Post by N1EYZ » Mon Dec 17, 2018 5:02 am
does anyone have an update to these instructions for Windows 10?
N1EYZ (Roger)
