WSJT-X configuration
Hi Gang, I have seen all the you tubes about using the SDR uno with WSJT X, But no step by step set up, like what rig do i select for the WSJT X program.
I have VSPE loaded, but dont know how to set it on SDR UNO any assistance Snip its WSJTX-X for SDR UNO dummies..
thanks regards, Ed
thanks regards, Ed
Re: WSJT-X configuration
You need to create a comport pair in VSPE
ie: COM 1 / 2, COM 3/4 or COM 5/6.
Set SDRuno up to use the first number of the VSPE comport pair
ie: 1, 3 or 5 within the RX CONTROL and enable it.
Set WSJT-X to use a Kenwood TS480 rig and assign it the second number of the VSPE comport pair
ie: 2, 4 or 6
Also explained here.
viewtopic.php?t=2547#p7727
ie: 2, 4 or 6
