SDRconnect v1.0.5 build 583e89db6 was released October 4th.
To operate this release with nRSP-ST, the firmware must be updated to at least 1.0.11
Changed
• Linux installers will only check for Ubuntu compatible packages
• To skip dependency checks on unsupported Linux distributions, use (replace example.run with downloaded .run installer filename) …
o NOTSUPPORTED=true ./example.run
• Linux minimum HamLib supported version set to 4.5 (recommend 4.5.5 to 4.6.5)
Corrected Defects
• Pressing TAB repeatedly or holding it down could cause SDRconnect to unexpectedly exit
• mp3 library was missing from the Windows installer
• MacOS server would abort due to a bind failure
• Cleaned up server list of streamable sources
• HamLib bridge missing from the Linux/ARM64 installer
• Rig Control – OmniRig interface updated to support either pmFreq or pmFreqA as defined in the rig ini file
SDRconnect v1.0.5 build e077f2ebe was released 26th September 2025
To operate this release with nRSP-ST, the firmware must be updated to at least 1.0.11 – this also has a fix for Safari 26 users
Added
• Diversity support over the network via server (requires RSPduo)
• MP3 Audio recording support
• Rig control support
o Omni-Rig (windows only)
o HamLib
• Waterfall gradient preview
• Show ticks on the RF gain slider
• Slider to change noise reduction strength
• Option to enable NFM deemphasis
• Option to display spectrum frequency markers in relevant unit
• Option to enable hold with decay on main spectrum
Changed
• Improved CW mode filter performance
• Application and server memory usage improvement
• Display application version in title bar
Corrected Defects
• Touch controls in the waterfall were active whether they displayed or not
• RDS decoder filtered out characters in the extended ASCII set
• RDS decoder did not work at all sample rates
• Copy/paste frequency between tabs required a frequency in the destination tab to be selected
• Switching frequency tabs whilst the edit field padlock was open caused a crash
• Bandwidth resize could be performed for DSB and LSB when mouse was in the frequency bar
• Inconsistent style on remote devices dialog
• IQ playback file selection was disabled when streaming was stopped
NRSPAdministrator (for nRSP-ST)
Added
• Logging of connection activity
• Ability to take control from client (admin user only)
• Ability to assign control to a user
• List of active/connected users
Corrected Defects
• Editing users required a password entry whether it changed or not
• Date/Time of recording shown was always UTC regardless of regional setting
